OS6850E - qos log forward to syslog?!
3rdm4r
Post by 3rdm4r »
Hey Folks!
is there a possibility, to foward the output from "show qos log" to a defined "swlog output socket x.x.x.x"?
The content of "swlog" comes on my syslog server - would be great to see the qos log also there.
Thanks in advance!
Greets
Re: OS6850E - qos log forward to syslog?!
No, I've never heard that this is possible.
In my opinion it is also not the best idea to log all your matched policies (I use it only for troubleshooting).
3rdm4r
Post by 3rdm4r »
Thanks for the quick response...
we found the command to relay the qos-log messages to the local swlog/syslog.
qos log console
qos forward log
show qos config
In this switch config are not many policies, so no problem with flooding ;)
Topic can be closed
