Hi guys
Is it possible to change the imap port for a 4645 to e.g. port 993?
4645 Change Imap port
Re: 4645 Change Imap port
not possible...
regards...
regards...
My customer has told me that they have connected to the mailbox and even downloaded voicemails using SSL! So it seems to work.
- cavagnaro
Well...maybe they enabled secure access? And how did they put the SSL certificate?
yes... have the same question about the certificate...
also when 4645 is activated, it will listen only to port 143:
regards...
# netstat -tulpn | grep imap
tcp 0 0 0.0.0.0:4033 0.0.0.0:* LISTEN 13712/vimap
tcp 0 0 0.0.0.0:143 0.0.0.0:* LISTEN 13713/imapd
I will eventually be in contact with the customer, see how they did this and post what I find
Is it possible to disable all IMAP ports even if 4645 voicemail is enabled?
Have a customer who is concerned about unauthenticated IMAP port being open on OXE on their network.
And if this is not possible with 4645 activated, is there a process for IMAP over SSL using port 993. How to activate the port 993 on OXE?
SWINSTU
ACSE OXE R12.1
ACSE 8770 R3.2(4760 R5.x)
ACSE OT R2.3 IP/SIP and UC&C
ACSE OXE R12.1
