Getting Started With OXE
ampcne25
Post by ampcne25 »
Is there a guide for how to setup a virtual machine with OXE software. I'm trying set lab to start learning about the OXE and there are a lot of software images in the partner download area and I can't figure out which is which. Or it would be nice to point me to the right documents to get started.
PS. I'm an absolute beginner to the OXE and know very little about it.
oldboy
Re: Getting Started With OXE
Post by oldboy »
http://www.alcatelunleashed.com/viewtopic.php?t=20552
read this, there is a procedure, make sure you configure it as a blade server when using PC Installer,
