7705 SAR-8/18's MPLS Warning message
et2house
Post by et2house »
I'm getting error messages that repeat every few minutes that look like this:
426125 2017/12/15 15:19:16.11 PST WARNING: SYSTEM #2008 Base MPLS
"vRtrMplsXCTable: Sender xxx.xxx.xxx.19, LspId 9706, Endpoint xxx.xxx.xxx.24, TunnelId 63590 managed object deleted"
426124 2017/12/15 15:19:15.78 PST WARNING: SYSTEM #2007 Base MPLS
"vRtrMplsXCTable: Sender xxx.xxx.xxx.19, LspId 9706, Endpoint xxx.xxx.xxx.24, TunnelId 63590 managed object created"
Found on every node in the ring, but not on spurs. Same error message but different IP addresses on another ring:
481546 2017/12/15 11:29:44.08 PST WARNING: SYSTEM #2008 Base MPLS
"vRtrMplsXCTable: Sender xxx.xxx.xxx.51, LspId 16246, Endpoint xxx.xxx.xxx.203, TunnelId 65394 managed object deleted"
481545 2017/12/15 11:29:44.04 PST WARNING: SYSTEM #2007 Base MPLS
"vRtrMplsXCTable: Sender xxx.xxx.xxx.51, LspId 16246, Endpoint xxx.xxx.xxx.203, TunnelId 65394 managed object created"
I don't know what it means, guessing it's trying to create an LSP path because when I create a path I get a similar message, but without the delete part. The .24 IP is a routed interface to a neighboring node, not the system interface.
I have checked all the mpls paths, lsp's, sdp's and services on the .19 node and everything appears to be configured correctly.
Return to “7705 SAR”
