lag and bfd issues in eve-ng
plawansai
Post by plawansai »
Does the eve-ng support lag and bfd?
A:PE1# show port
Port        Admin Link Port    Cfg  Oper LAG/ Port Port Port   C/QS/S/XFP/
Id          State      State   MTU  MTU  Bndl Mode Encp Type   MDIMDX
1/1/2       Up    Yes  Link Up 8936 8936  200 netw dotq xcme   GIGE-LX  10KM
I also attach the capture packet.
lag nokia.zip
And the bfd always flap. :shock:
Thank you very much.
plawansai
Re: lag and bfd issues in eve-ng
Post by plawansai »
I found it, they should be configure different administrative-key. 8)
GabrielHorney
Post by GabrielHorney »
Hello
What do you mena with different administrative-key ?
Return to “7750 SR”
