Please help, on OS6860E stack switches, write memory or write memory flash-synchro will gives me the error below
ERROR: Write memory is not permitted when switch is running in certified mode
Re: ERROR: Write memory is not permitted when switch is running in certified mode
can you execute the command show running directory and post me the output
first you have to say what is your start or running directory:
copy certified working make-running-directory
now working is the used directory. you can check with "show running-directory"
CONFIGURATION STATUS
Running CMM : MASTER-PRIMARY,
CMM Mode : VIRTUAL-CHASSIS MONO CMM,
Current CMM Slot : CHASSIS-1 A,
Running configuration : CERTIFIED,
Certify/Restore Status : CERTIFIED
SYNCHRONIZATION STATUS
Flash Between CMMs : SYNCHRONIZED,
Running Configuration : NOT SYNCHRONIZED
