Hi Frank:
I am Commissioning Engineer. In this moment I am installing a 9600 LSY SDH microwave radio Alcatel.This radio is managed by 1320 Craft Terminal (CT SDH/Optical Networks). I have no technical documentation about it. I`d like to know where I could get this information.
Paul
documentattion about 1320 Craft Terminal (CT SDH/Optical Net
Re: documentattion about 1320 Craft Terminal (CT SDH/Optical Net
zanex
I have done some work on old E3 9600's there are several varients - you will also need to get the managment software you dont just connect with a terminal to them and i found it quite hard to find. As for documentation make sure you get it for your model as they all have different outputs/freq's for the specific countries.
knightr1der
Cav, is there no other special animal dance like maybe a peacock dance rather than chicken dance with only 6 candles instead of 67 that we can help carrillops with?cavagnaro wrote:We basically see all PBX and some data equipments (switches/routers) for that info you need to ask to Alcatel IND the how to. That is another level, we are under the e-Business level.
Only joking carrillops, like Cav says - this forum is only here for some data and PBX stuff, not SDH etc.. and my limited knowledge on virtual containers and add/drop multiplexing won't help you much either
