Low volume in SLI
espinosa
Low volume in SLI
Post by espinosa »
I have 2 OXE R11.0.1, each with 1 IPMG. In the MGs, all the SLI extensions have low volume in conversation.
¿There is a way to increase this volume?
TIA
Re: Low volume in SLI
Go to mgr > system > descend hierarchy > Z audio parameter
Rec.Gain for QDSP: 108
Rec.Send Gain for QDSP: 160
Send Gain for QDSP: 51
Adjust these values as per requirement and check the output of the audio.
The board needs to be rebooted.
Make note of the values you change, so you can revert in case you need to.
espinosa
Post by espinosa »
Thanks, I'll try and comment.
Return to “Media Gateway”
