Analog to IP phone having bad audio quality via Loudspeaker
HUSSAINQCS
Post by HUSSAINQCS »
Hi ,
I having OXE R11.1
When analog user calls to IP user via loudspeaker and there is a break in voice like one way communication
Is any body faced issue what could be the probable reason ?
Re: Analog to IP phone having bad audio quality via Loudspeaker
If you have one way communication, your network is not setup correctly.
is one way communication happens only on speakerphone ?
Is your network full duplex ?
HUSSAINQCS
Yes Frank with Panasonic it was good but with Cetis 3100MWD5 it was getting voice chop during talking & Listening
so if it works with one brand of phone and not the other, did you switch the phones to see if the issue follows the phone line itself , or the set ?
HUSSAINQCS
Yes the issue with all sets of Cetis phone installed at site.
Return to “IP”
