Can not reinstall the hard drive and upgrade R12 for cpu7-2 card
Luan-Duong
Post by Luan-Duong »
Hi .
Can not reinstall the hard drive and upgrade R12 for cpu7-2 card for OXE Crystal
CPU7 >3
cascaded counter RESET and Watchdog restarted with 255 min
ACT4400 specific INSTALLATION data input:
Standard installation (y/n, default is y) ? :
TEL version ? :
Phase 1: address determination and bootfile selection
NB: All parameters below are optionnal.
Bootp received address : 0.0.0.0
My Default internet Address :0.0.0.0
New Internet Address : ?>/n
DHS3 IP address used :0.0.0.0
DHS3 new IP address :0.0.0.0
Name of default BOOTP/TFTP server : *** Unknown ***
Name of a new BOOTP/TFTP server :
Default loaded file :
New loaded file :
IP address determination
BOOTP request in progress -> 0:80:9F:9C:90:2A
Bootp resp IP addr src :192.168.3.32
bootp server and TFTP server are the same
TFTP server IP addr ( siaddr) : 192.168.3.32
eth source address=14:18:77:AF:23:50
bootfile = /bootp/linux/95.0/alize/startup.txt
Netmask : 255.255.255.0
Our Hostname : OXE_1 (192.168.3.33)
My IP address
192.168.3.33
My SUBNET mask
255.255.255.0192.168.3.33
Server Name: Dell3459
NIS domain Server Name:
NIS Domain :
TFTPLOAD STARTED using ip=192.168.3.32 - Bootp Server Dell3459 - File Name /boo
size of last packet: 216
TFTPLOAD COMPLETE - file size 216
EBbread:Location : 0, pAddr= 64E8,Count =48,pFileSize= 64E0
COFF file.Ebread Ok for : File=6F6F622F ,FileSize=6C2F7074 , SeqNo=78756E69
ERROR: Not an iAPX 386 COFF file.
Please help me , on this case .
Re: Can not reinstall the hard drive and upgrade R12 for cpu7-2 card
Read TC 1708.
For A4400 method - you need enter "TEL version" and "New loaded file"
Luan-Duong
vad wrote: 07 Sep 2017 23:36 Read TC 1708.
Hi Bro,
Thank for your support ,
New loaded file ? . I do not understand, where loaded New file from ?, you can only help me (I need reinstall Release R12 (M1403)).
Thank.
SW loaded in dhs3mgr folder - f.e. folder M1403 (core), M140315 (patch)
In PC Installer - download method - A4400
In com port enter:
TEL version m140315.xx (xx - your country code, in my case ru - Russia)
"Enter" for next field except
New loaded file %95.0 (95.0 just for example - you need enter folder name from /dhs3mgr/m1403/pcmao/boot_res/bootp/Linux/..)
Do you have R12 documentation pack? In Technical bulletin folder - exist TC, TC 1708 - Installing and using the OmniPCX Enterprise PC Installer Software
alexeik
Post by alexeik »
with release 12 there is a new bios for CPU7-2. You need the new bios file, put it on the old release, reboot, the the cpu7-2 gets flashed, and then you can install the new release...
Luan-Duong
Help me,
R12 software download from Alcatel as follows:
C:\dhs3mgr\m1403\pcmao\boot_res\bootp\linux\109.000
We need press %109.000 ?
Thanks for your support.
alexeik
Post by alexeik »
yes %109.000
did you flash the bios?
Luan-Duong
Flash the bios on cpu7 card ? . I do not understand, Please help me . Thanks.
HUSSAINQCS
Post by HUSSAINQCS »
Are trying to put release in HDD ?
Return to “Shelf”
