DHCP Interface
EmptySet
DHCP Interface
Post by EmptySet »
Good morning,
I'm trying to configure one of these older switches to essentially be a 'dumb' switch. However, I can't find the command to set the interface to receive its IP via DHCP.
It doesn't recognize ip interface dhcp-client like the 6850 does and I can't find mention of another way in the guide.
Any one know how this can be done?
Thanks.
Re: DHCP Interface
dhcp-clients starts with 6.3 or 6.4. (I am not sure). And the 6800 ends with R6.1. You can't update it to a newer release. So this isn't possible.
Return to “OmniSwitch 6800”
