OXE connection to Cisco ATA 187
IP and Voice over IP
warrengauci
Post by warrengauci »
Hi, First of all well done for this great forum. I would like to ask if any one has connected ATA 187 to an OXE. I am trying to connect the ATA 187 to a SIP trunk on OXE, then connect an analogue terminal on the other end. Looks like the ATA187 goes to fetch the xml configuration file from the set TFTP server address after each reboot. Since OXE's tftp server is not accessible, did anyone find a way round this? Does anyone know if ATA187 can store the xml and keep this file and load it on the next reboot?
afaquekhan
Re: OXE connection to Cisco ATA 187
Post by afaquekhan »
What is VoIP port for trunking between alcatel oxo and alcatel oxe
afaquekhan wrote: 09 Jan 2022 23:29 What is VoIP port for trunking between alcatel oxo and alcatel oxe
hi for oxe signaling is @5060 , oxo uses 5060 as default port but u can change it if needed
Return to “IP / VoIP”
