Hi People
As I get the SDK files in the OXE, I need to do a PMS integration between OXE and EZEE Software.
Thanks for your help.
AHL SDK
Re: AHL SDK
There is no SDK for OXE...you need tsapi or CSTA licenses. What kind of integration is being done? What is EZEE?
Re: AHL SDK
looks like hotel software PMS etc.
http://www.ezeefrontdesk.com/index.php
as per Cav no SDK just get EZEE to wirte the ip interface module as per the specs from Alcatel Application Partner Program (AAPP).
basically they open comms on a port, use keep alives, and use the 2 way data comms as per the AHL specs. no SDK needed.
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
raimondruiz
Re: AHL SDK
Ezee is a software for hotel management, you want to integrate with oxe to handle check in check out, alarm clock, codes of problems in the rooms, etc. Http://www.ezeefrontdesk.com/
