6850 - Linksys switch always blocking
QtropMike
Post by QtropMike »
Ive been away from the 6850 for a couple years but am wanting to place this one back int eh loop as a standby router config
Simople setup right now one port plugged in 1/1 to a linksys srw2024 but it continully sets that port to blocked. If I disable stp its happy
I seem to remember some old issues with cisco 6509 and stp but any suggestions thanks
config
! VLAN :
ethernet-service mode vstk
vlan 1 1x1 stp disable flat stp disable name "VLAN 1"
! VLAN SL:
! IP :
ip service ftp
ip service ssh
ip service telnet
no ip service udp-relay
ip service http
ip service network-time
ip service snmp
no ip service avlan-telnet
ip service avlan-http
ip service avlan-secure-http
ip service secure-http
ip service avlan-http-proxy
arp filter 192.168.10.183
ip interface "vlan192" address 192.168.10.250 mask 255.255.255.0 vlan 1 ifindex
2
! IPX :
! IPMS :
! AAA :
aaa authentication http "local"
aaa authentication snmp "local"
! PARTM :
! AVLAN :
! 802.1x :
! QOS :
policy network group administrator 192.168.10.0 mask 255.255.255.0
policy condition allow_Mgmt_access source network group administrator destinatio
n network group Switch
policy condition deny_Mgmt_access source ip Any destination network group Switch
policy action allow_Mgmt_access
policy action deny_Mgmt_access disposition deny
policy rule allow_Mgmt_access precedence 100 condition allow_Mgmt_access action
allow_Mgmt_access
qos apply
! Policy manager :
! Session manager :
! SNMP :
! RIP :
! OSPF :
! ISIS :
! IPv6 :
! IP multicast :
! RIPng :
! OSPF3 :
! BGP :
! Health monitor :
! Interface :
interfaces 1/17 admin down
! Udld :
! Netsec :
! Port Mapping :
! Link Aggregate :
! VLAN AGG:
! 802.1Q :
! Spanning tree :
bridge mode 1x1
! Bridging :
! Bridging :
! Port mirroring :
sflow receiver 1 name OPMgr address 192.168.5.18 udp-port 9996 packet-size 1400
version 5 timeout 0
! UDP Relay :
ip helper pxe-support disable
! Server load balance :
! System service :
! SSH :
! VRRP :
! Web :
! AMAP :
! LLDP :
! Lan Power :
! NTP :
! RDP :
! VLAN STACKING:
! Ethernet-OAM :
devnull
Re: 6850 - Linksys switch always blocking
Post by devnull »
You should somewhere drop a question, which makes it much easier to understand.
What STP is is running on the linksys?
I would feel uneasy with STP disabled.
Set Both the Linksys and the Alcatel to RSTP (and not 1x1) and they should behave well (as long as you do not have a second cable between Linksys and Alcatel)
QtropMike
Post by QtropMike »
Morning
Turning it off was only a testing solution , The linksys switches have been in place for 3 years now and were all single purpose switches. Never really looked much at them. I moving them their functions over to teh 6850 hence the need for thecross connects now.
Anyway I had never noticed that the Linksys switches default to no STP and hadnt thought to even check it
So yes you guessed it its working fine now
thanks
Mike
