Migrate to 4504 to 4010 with AP93 and AP92
MaMadrid
Post by MaMadrid »
Hi all.
I´ve a customer with two OAW-4504-0 and several access point AP-92 and AP93. For support renewal he needs change both oaw-4504 for two 4010-RW instead because the 4504 was end of live. About this, i´ve the next cuestion. The OAW-4010 support the AP-92 and AP93?
AP-92 and AP93 is not on EoL yet and the customer doesn´t want change this equipments.
Best regards.
Re: Migrate to 4504 to 4010 with AP93 and AP92
the supported software is important:
4010 6.4.1 or newer
4504 6.3.1 to 6.4.4
AP92/93 6.3.1 to 6.4.4
So the AP will work with 4010 f.e. in release 6.4.4 (but not in 6.5)
MaMadrid
Post by MaMadrid »
Fine.
Thanks so mucho for you reply Silvio.
Greetings.
Return to “OmniAccess WLAN Switching Systems (OEM)”
