GRE tunnel configuration
dushanraman
Post by dushanraman »
Hi folks,
Could anyone provide some insight on how to configure a GRE tunnel between 2 x 7705 nodes.
I was only able to find configs to intergrate SDP to use GRE tunnel, but nothing of how to create a GRE tunnel.
Would be great if someone could provide an example or just point out what needs to be done.
Thank you.
thekotaksampah
Re: GRE tunnel configuration
Post by thekotaksampah »
I think in Nokia Router to create GRE tunnel, we just use that you mention above.
Thank You
Technical Blog: ngoprek.achyarnurandi.id
dushanraman
Hi Thanks for that will try to implement it and see how it goes.
Appreciate the confirmation.
dushanraman
thekotaksampah wrote:Hi,
Thank You
Thanks mate, I tested this and it worked, pretty straightforward thats what confused me the most. It was too simple to configure so was wondering whetehr I was missing something.
Appreciate your response.
Cheers!
jhonnyeriksson
Post by jhonnyeriksson »
Do you have any example configuration for standard GRE tunnel setup in 7750SR? I cant find one in the regular 7750SR configuration guides. Is it required to have a ISA module?
Thanks, Best Regards
DoobieHowserMD
Post by DoobieHowserMD »
You do not need an ISA card to create a GRE tunnel for a SDP. Here is an example of configuring the SDP over GRE:
configure service sdp <sdp-id> create
far-end x.x.x.x/x
no shutdown
exit
Then you will type in show service sdp and the list will show you the Delivery Method which will say GRE. The default configuration of a SDP is to be attached to a GRE tunnel. You have to change the command in order to bind it over LDP/RSVP. That would look something like configure service sdp <sdp-id> mpls create.
lo0
Post by lo0 »
Specify the desired Transport/Delivery Type (in our case, GRE) when creating the SDP.
configure service sdp <$sdp_id> gre crete
Return to “7705 SAR”
