OmniSwitch 6850 issues connection via console port
Xari
Post by Xari »
Hello All,
I bought few used 6850 from ebay and they came completely locked, no access to web gui, telnet or ssh. I tried connecting with the console port with the following settings :
speed: 9600
databits: 8
stop bits: 1
parity : none
flow control : XON/XOFF
I tried using Putty and TeraTerm with no luck. When I power the switch i don't see nothing in the console window. Any suggestions how to factory reset this switch ?
Thank you
Re: OmniSwitch 6850 issues connection via console port
use the correct serial adapter:
viewtopic.php?f=194&t=23718&p=86680&hil ... pin#p86680
viewtopic.php?f=337&t=19473&p=69629&hil ... pin#p69629
What powersupply did you have? Any LED at the front?
Xari
Post by Xari »
I need to find this specific serial adapter that works with OmniSwitch, thanks for pointing me to the right direction .
