Set must be multi line! ERROR
cemsayin
Hello Good Working.
I can not add numbers in supervision mode f1.
I encountered this problem.
I build again erased numbers
Bazı abonelerde bu f1 tuşuna yani 73 numaralı tuşa sorunsuz supervision ekleyebiliyorum.
Help Me Thank you
Merhaba Bu yazı
Help Me Thank you
Merhaba Bu yazı
Re: Set must be multi line! ERROR
Add a multi line key on the set keys
cemsayin
please
There is no Multi line key configured, instead of Programming should say MultiLine...read basic documentation pls
For multiline - at least one key must be "multi-line" (not programmed).
First multi-line key shall be wit number=set directory number, another multi-line keys can be with another number.
F.e. for set 3000 you need to create one multi-line key with number 3000.
You can create more multi-line keys 3000 (set can receive many calls to 3000 at the same time).
You can create multi-line key f.e. 2000 (number must be free) - in this case you can call set by dialling 3000 or 2000. Incoming calls will be present on corresponding multi-line key.
bad try... i'll make your work only if you pay my bill.cemsayin wrote:team viewer 10 ıd : 564920340- password 9443
regards...
