How to config guest management in hotel
Danaity
Re: How to config guest management in hotel
Post by Danaity »
mustafa.ahmad wrote:
04 Sep 2018 05:02
You will need to create a suite and then add the two extensions .
At check in , both the suite extension will get checked in and also you can call the main suite number 1000 to ring both 2000 and 2001
Hi I'm also facing similar (almost) problem.
Were you able to get some help or guide to solve your problem?
If yes, will you be kind enough to share it :)
https://athletesphysiques.com/
mustafa.ahmad
Post by mustafa.ahmad »
For the suite creation, go to mgr/applications/hotel/descend hierarchy/hotel suite.
In this menu you can create the suites. Give the main extension number and additional extensions.
The suite will be referred by the main directory number.
ReubenHensler
Post by ReubenHensler »
MichealFigueroas wrote:
11 Oct 2454 07:25
phukientfongdai wrote:
03 Jan 2437 18:25
Who can help me guide some steps to config this
I'm also facing similar (almost) problem. Were you able to get some help or guide to solve your problem? If yes, will you be kind enough to share it?
See your hotels in real time and make sure everything gets done smoothly and quickly.
HenryFlores
Post by HenryFlores »
04 Sep 2018 05:02
Thanks for the help buddy was facing this problem even after trying that way. :) .
LeonPatrick
Post by LeonPatrick »
04 Sep 2018 05:02
while reducing hotel energy consumption.
lanaroady
Post by lanaroady »
MichealFigueroa wrote:
24 Jun 2018 00:39
phukientongdai wrote:
13 Sep 2016 02:39
Are these things not similar and good enough to mark the things with or without having the guide
lanaroady
Post by lanaroady »
13 Sep 2016 02:39
All of these cases are enough because you can't hide
MichaelSingleton
Post by MichaelSingleton »
Danaity wrote:
06 Jan 2019 07:44
04 Sep 2018 05:02
Yes, bro here also I am facing the same problem.
oldboy
Post by oldboy »
I am happy to help at a fee.
Return to “Application”
