netadmin -m Error
hassansalem
netadmin -m Error
Post by hassansalem »
Thanks every body in advance ,
I'm installing oxe common hard ware with duplication feature , while the matstercopy twincpu is being running the power (Disconnected )failed , when the power back the pabx started normally with duplication ,I tried to run netadmin -m for both communication servers , one of them is ok and the other gives me the attached error , Could you please assist me to solve this problem ?
on the other hand ,I 'd like to add something , I already restored the database and ops from the CPU hard disk but the problem not solved .
Waiting your appreciated advise.
Krusty65
Re: netadmin -m Error
Post by Krusty65 »
Did you reload the linux data (if you backed it up), from the error it looks like you have a corrupt file.
Other option would be to do a mastercopy again but just select the linux option.
K.
alex
Post by alex »
Why not run "netadmin" from scratch? It would take around 60 seconds and do no harm to the system.
If you like to live dangerously then try "netadmin -m" option 17 "history of last actions" and make restore.
hassansalem
Thanks all in advance ,
Mr. Krusty65 , I already did try to run mastercopy command for more than time and the result was the same error .
Mr.Alex , I did try to run netadmin -m option 17 as per your appreciated advise but not executed ,I remember that ,I selected the clean history option while I'm configuring the duplication .
Could you please assist me for second time to solve this problem?
waiting your appreciated fast response .
alex
Post by alex »
hassansalem wrote: I remember that ,I selected the clean history option while I'm configuring the duplication .
Next time you won't do that, won't you?
hassansalem wrote:Could you please assist me for second time to solve this problem?
You have all information configured in the main CPU. Just check configuration there and configure it on the stand-by CPU.
