Dynamic messages configured but not downloaded
andy_khanh
Post by andy_khanh »
Hi All
Could you please some step to fix that problem. I have import the file into database and created VG nummber and Assignment. But when i do "vgstat 2 27". I got the message.
etat_vg = VG_STABLE (0)
Slot 1 : Card status register = 4E   Identifier =
         Static voice guides         Language : 255 - Not used
Slot 2 : Card status register = 4E   Identifier =
Slot 3 : No Memory Card
Slot 4 : Card status register = 4E   Identifier =
Slot 5 : Card status register = 3C
         Dynamic voice guides
         Total size           = 2096128 bytes (1024 pages) (524 sec)
         Free size            = 2096128 bytes (1024 pages) (524 sec)
         Fill ratio           = 0.0 %
         Available size       = 2096128 bytes (1024 pages) (524 sec)
Number of present messages = 0
Message syntax : xxxx = static, xxxx-d = dynamic, xxxx-D = dynamic and static
+------+ Press 'CR' to continue or 'q' to quit +------+
Dynamic messages configured but not downloaded :
UNKNOWN    (755)   file : vntech   length : 120466 bytes ( 30 pages) (15.4 sec)
Dynamic messages waiting for download :
Available voice guides channels = 16
Active channel :
What should i do now?
Please help
Re: Dynamic messages configured but not downloaded
import the file into database - what do you mean?
andy_khanh
I have uploaded my custom audio to OXE by AAS. Then i did some step as metions in "Voice Guide and Music-on-hold Guide" : Created "Assignment", modified "Dynamic Voice messages files" . But i don't know. What must i do next?
Your explanation not clear - you say "was done some steps" and not explain your management.
So not easy to give advise.
I have just one idea - restart VG board and check incidents about VG downloading (may be you manage wrong name for VG file or put in wrong folder)
andy_khanh
Here is my log of incidents.
28/07/16 15:50:06
28/07/16 15:50:23 000001I|---/--/-/---|=2:1006=DPNSS Prefix Missing, No DPNSS prefix added.
28/07/16 15:50:23 000001I|---/--/-/---|=4:2199=A4400 Version : R11.2-l2.300-25-c-vn-c82
28/07/16 15:51:02 000001I|---/--/-/---|=2:2176=A dynamic patch has been installed for TEL
28/07/16 15:51:56 000001M|---/--/-/---|=5:2009=Initialisation  CPU role MAIN
28/07/16 15:51:56 000001M|---/--/-/---|=5:2019=UA_FICTIF coupler commissioning
28/07/16 15:51:56 000001M|---/--/-/---|=5:2019=Z coupler commissioning
28/07/16 15:51:56 000001M|---/--/-/---|=5:1367=DECT network initialization
28/07/16 15:51:56 000001M|---/--/-/---|=5:5904=Remote extension network initialization
28/07/16 15:51:56 000001M|---/--/-/---|=4:0425=PRS related activity : Interface handler started
28/07/16 15:51:56 000001M|019/01/-/---|=5:2019=INTIPA/INTIP3A coupler commissioning
28/07/16 15:52:00 000001M|002/00/-/---|=4:0740=Beginning of an INT/IP downloading @:00.80.9f.be.59.ef (binmg3)
28/07/16 15:52:00 000001M|002/00/-/---|=5:0741=End of downloading of an INT/IP board @:00.80.9f.be.59.ef (binmg3)
28/07/16 15:52:04 000001M|---/--/-/---|=2:0276=External accounting application ??? : NO RECOVERY
28/07/16 15:52:07 000001M|002/00/-/---|=4:0740=Beginning of an INT/IP downloading @:00.80.9f.be.59.ef (binamcvb642x
28/07/16 15:52:07 000001M|002/00/-/---|=5:0741=End of downloading of an INT/IP board @:00.80.9f.be.59.ef (binamcvb642x
28/07/16 15:52:08 000001M|002/00/-/---|=4:0740=Beginning of an INT/IP downloading @:00.80.9f.be.59.ef (bin642xconf.
28/07/16 15:52:08 000001M|002/00/-/---|=5:0741=End of downloading of an INT/IP board @:00.80.9f.be.59.ef (bin642xconf.
28/07/16 15:52:13 000001M|002/00/-/---|=5:0409=The inter-ACT link over IP from (19 1) is up
28/07/16 15:52:13 000001M|002/00/-/---|=2:5864=GD: Configuration file checking alarm (lanpbx) 1
28/07/16 15:52:13 000001M|002/00/-/---|=3:5874=telnet service closed
28/07/16 15:52:13 000001M|002/00/-/---|=0:5857=GD/GA/INTIP/RGD: reason of reboot 2
28/07/16 15:52:14 000001M|002/00/-/---|=3:5874=telnet service closed
28/07/16 15:52:15 000001M|002/27/-/---|=4:0260=Beginning of downloading /DHS3ext/vgadpcm/flash/custom/adpcmmoh
28/07/16 15:52:16 000001M|002/01/0/000|=4:2080=MIC/SYNC access is synchronizing on Board (2,1)
28/07/16 15:52:16 000001M|---/--/-/---|=5:2141=SET resources quantity normal
28/07/16 15:52:17 000001M|---/--/-/---|=4:0601=AFE_ROOM_DISPLAY: 1 510
28/07/16 15:52:20 000001M|---/--/-/---|=5:1567=DHCP server started
28/07/16 15:52:23 000001M|002/27/-/---|=4:2501=Dow: file /DHS3ext/vgadpcm/flash/custom/adpcmmoh reading error
28/07/16 15:52:23 000001M|---/--/-/---|=4:2504=Dow: thread not found for 2,27,0 cpl
28/07/16 15:52:24 000001M|002/27/-/---|=4:0260=Beginning of downloading 755_vntech
28/07/16 15:52:25 000001M|---/--/-/---|=3:1125=external alarm : "mtcl login"
28/07/16 15:52:27 000001M|---/--/-/---|=2:5815=Major failure in SIP component
28/07/16 15:52:27 000001M|000/00/-/---|=5:5800=10 SIP trunk group put into service
28/07/16 15:52:27 000001M|---/--/-/---|=0:5812=SIP external gateway 1 is in service
28/07/16 15:52:27 000001M|---/--/-/---|=0:5812=SIP external gateway 2 is in service
28/07/16 15:52:28 000001M|002/27/-/---|=4:2508=Dow: unexpected message 1,4,208
28/07/16 15:52:28 000001M|002/27/-/---|=3:2474=Failed to download file for the VG message No 755
28/07/16 15:52:29 000001M|002/27/-/---|=4:2476=Erasing voice message 755 on partition 5
28/07/16 15:52:43 000001M|002/00/-/---|=5:2019=GD/GD3 coupler commissioning
28/07/16 15:52:44 000001M|002/01/-/---|=5:2019=PCM coupler commissioning
28/07/16 15:52:46 000001M|002/06/-/---|=5:2019=NDDI coupler commissioning
28/07/16 15:52:59 000001M|002/27/-/---|=4:2491=GPA(2,27) virtual coupler commissioning of the associated coupler GD/GD3(2,0)
28/07/16 15:53:01 000001M|002/05/-/---|=5:2019=Z coupler commissioning
28/07/16 15:53:01 000001M|002/04/-/---|=5:2019=Z coupler commissioning
28/07/16 15:53:18 000001M|001/00/0/052|=3:0386=Sig. on IP set: No response from de set 00:80:9f:c2:7e:6c,3009
28/07/16 15:53:18 000001M|---/--/-/---|=2:2140=Alarm : SET resources quantity critical
28/07/16 15:54:49 000001M|002/27/-/---|=3:2490=Loss of a virtual coupler GPA (2,27) of the associated coupler GD/GD3 (2,0)
28/07/16 15:54:50 000001M|002/27/-/---|=4:0260=Beginning of downloading /DHS3ext/vgadpcm/flash/custom/adpcmmoh
28/07/16 15:54:57 000001M|002/27/-/---|=4:2501=Dow: file /DHS3ext/vgadpcm/flash/custom/adpcmmoh reading error
28/07/16 15:54:57 000001M|---/--/-/---|=4:2504=Dow: thread not found for 2,27,0 cpl
28/07/16 15:54:58 000001M|002/27/-/---|=4:0260=Beginning of downloading 755_vntech
28/07/16 15:55:02 000001M|002/27/-/---|=4:2508=Dow: unexpected message 1,4,208
28/07/16 15:55:02 000001M|002/27/-/---|=3:2474=Failed to download file for the VG message No 755
28/07/16 15:55:02 000001M|002/27/-/---|=4:2476=Erasing voice message 755 on partition 5
28/07/16 15:55:22 000001M|000/06/-/---|=5:2169=Main CPU initialization completed
28/07/16 15:55:32 000001M|002/27/-/---|=4:2491=GPA(2,27) virtual coupler commissioning of the associated coupler GD/GD3
I'm newbie. So i don't know what i did is right or not. Now we need configure the OXE, so when external and internal users call to. They will hear the voiceguide first. I uploaded my voiceguide as mention here viewtopic.php?t=242. Then did some steps in the Technical document.
-Selecting languages
-Assigning a user languages to a user
-Creat Voice Guide Index MG
Can u pls give me some advice.
Thns !
For the begining - you have incident - problem with Music-on-hold (wrong file from AAS, not in this folder ... etc)
Start your problem discovery from MOH - more easy - standard file, standard procedures.
For dynamic VG - you have incident too - may be wrong format (not adpcm), may be wrong folder/ file attributes
Return to “Voice Guides”
