I am completely new to the Alcatel 7210 equipment so apologise in advance.
I am am trying to transfer services from an Omniswitch 6855 to a 7210 SAS-M.
The 7210 is to accept trunked traffic on port 1/1/1 and be able to ping the different pc devices in the topology below.
I have created port 1/1/1 as follows.
config
port 1/1/1
description "TEST*
ethernet
mode hybrid
access
exit
encap-type dot1q
exit
no shutdown
exit
router
interface vlan90
address 172.16.0.1/24
port 1/1/1:90
no shu
exi
interface vlan10
address 10.10.10.1/24
port 1/1/1:10
no shu
interface vlan20
address 10.10.20.1/24
port 1/1/1:20
no shuThis is the configuration that was on the Omniswitch , which is shown in the drawing.
! Stack Manager :
! Chassis :
system name MerseyTest
system timezone WET
! Configuration:
! VLAN :
ethernet-service mode vstk
vlan 1 1x1 stp disable flat stp disable name "VLAN 1"
vlan 10 enable name "VLAN 10"
vlan 20 enable name "VLAN 20"
vlan 30 enable name "VLAN 30"
vlan 40 enable name "VLAN 40"
vlan 50 enable name "VLAN 50"
vlan 60 enable name "VLAN 60"
vlan 90 enable name "VLAN 90"
vlan 90 port default 1/1
vlan 90 port default 1/2
vlan 90 port default 1/3
! VLAN SL:
! IP :
ip service all
ip interface "10" address 10.10.10.1 mask 255.255.255.0 vlan 10 ifindex 1
ip interface "20" address 10.10.20.1 mask 255.255.255.0 vlan 20 ifindex 2
ip interface "30" address 10.10.30.1 mask 255.255.255.0 vlan 30 ifindex 3
ip interface "40" address 10.10.40.1 mask 255.255.255.0 vlan 40 ifindex 4
ip interface "50" address 10.10.50.1 mask 255.255.255.0 vlan 50 ifindex 5
ip interface "60" address 10.10.60.1 mask 255.255.255.0 vlan 60 ifindex 6
ip interface "90" address 172.16.0.1 mask 255.255.255.0 vlan 90 ifindex 7
! IPX :
! IPMS :
ip multicast status enable
ip multicast querying enable
ip multicast vlan 10 status enable
ip multicast vlan 20 status enable
ip multicast vlan 30 status enable
ip multicast vlan 40 status enable
ip multicast vlan 50 status enable
ip multicast vlan 60 status enable
ip multicast vlan 90 status enable
! AAA :
aaa authentication telnet "local"
aaa authentication http "local"
! PARTM :
! AVLAN :
! 802.1x :
! QOS :
qos port 1/1 trusted
qos port 1/2 trusted
qos port 1/3 trusted
qos port 1/4 trusted
qos port 1/5 trusted
qos port 1/6 trusted
qos port 1/7 trusted
qos port 1/8 trusted
qos port 1/9 trusted
qos port 1/10 trusted
qos port 1/11 trusted
qos port 1/12 trusted
qos port 1/13 trusted
qos port 1/14 trusted
qos port 1/15 trusted
qos port 1/16 trusted
qos port 1/17 trusted
qos port 1/18 trusted
qos port 1/19 trusted
qos port 1/20 trusted
qos apply
! Policy manager :
! Session manager :
session timeout cli 60
session prompt default "MG-Test->"
! SNMP :
! RIP :
! OSPF :
load ospf
ip ospf area 0.0.0.0
ip ospf area 0.0.0.1
ip ospf area 0.0.0.2
ip ospf area 0.0.0.3
ip ospf area 0.0.0.4
ip ospf interface "10"
ip ospf interface "10" area 0.0.0.1
ip ospf interface "10" cost 10000
ip ospf interface "10" status enable
ip ospf interface "20"
ip ospf interface "20" area 0.0.0.2
ip ospf interface "20" cost 10000
ip ospf interface "20" status enable
ip ospf interface "30"
ip ospf interface "30" area 0.0.0.3
ip ospf interface "30" cost 10000
ip ospf interface "30" status enable
ip ospf interface "40"
ip ospf interface "40" area 0.0.0.4
ip ospf interface "40" cost 10000
ip ospf interface "40" status enable
ip ospf interface "50"
ip ospf interface "50" area 0.0.0.2
ip ospf interface "50" cost 10000
ip ospf interface "50" status enable
ip ospf interface "60"
ip ospf interface "60" area 0.0.0.4
ip ospf interface "60" cost 10000
ip ospf interface "60" status enable
ip ospf status enable
! ISIS :
! IPv6 :
! IP multicast :
ip load pim
ip pim sparse status enable
ip pim dense status disable
ip router router-id 1.1.1.1
! RIPng :
! OSPF3 :
! BGP :
! Health monitor :
! Interface :
! Udld :
! Netsec :
! Port Mapping :
! Link Aggregate :
! VLAN AGG:
! 802.1Q :
vlan 10 802.1q 1/1 "TAG PORT VLAN 10"
vlan 20 802.1q 1/1 "TAG PORT VLAN 20"
vlan 30 802.1q 1/2 "TAG PORT VLAN 30"
vlan 40 802.1q 1/2 "TAG PORT VLAN 40"
vlan 50 802.1q 1/3 "TAG PORT VLAN 50"
vlan 60 802.1q 1/3 "TAG PORT VLAN 60"
! Spanning tree :
bridge mode 1x1
! Bridging :
! Bridging :
! Port mirroring :
! UDP Relay :
ip helper pxe-support disable
! Server load balance :
! System service :
swlog output socket 10.10.10.10
swlog console level info
! SSH :
! VRRP :
VRRP 10 10 DISABLE
VRRP 10 10 PRIORITY 1 PREEMPT INTERVAL 1
VRRP 10 10 ADDRESS 10.10.10.254
VRRP 10 10 ENABLE
VRRP 20 20 DISABLE
VRRP 20 20 PRIORITY 1 PREEMPT INTERVAL 1
VRRP 20 20 ADDRESS 10.10.20.254
VRRP 20 20 ENABLE
! Web :
! AMAP :
! LLDP :
! Lan Power :
! NTP :
! RDP :
! VLAN STACKING:
! Ethernet-OAM :
Kind Regards
Adrian
