debug voip capture command - Mediant Software E-SBC
swinstu
Post by swinstu »
I have a customer who is experiencing 2 out 100 calls with no audio for inbound or outbound calls on their SIP trunk.
I have logged a call with the carrier who has requested a packet capture at the demarcation point which is the OT-SBC - Mediant Software E-SBC
The guide from the SBC userguide advises as follows:
Capturing VoIP Network Traffic
You can capture VoIP network traffic by sending traces to the CLI or to a file that is later
sent to a TFTP server. The traffic can be captured using the following CLI commands to
start the debug capture process:
debug capture voip
Any suggestions on how to capture the WAN leg of the traffic?
I have tried "debug capture voip interface vlan #" (# being the vlan ID of the WAN interface defined)
SWINSTU
ACSE OXE R12.1
ACSE 8770 R3.2(4760 R5.x)
ACSE OT R2.3 IP/SIP and UC&C
swinstu
Re: debug voip capture command - Mediant Software E-SBC
Post by swinstu »
All ok. Sorted. command is as follows:
Mediant SW# debug capture voip interface vlan 2 proto all host any
SWINSTU
ACSE OXE R12.1
Return to “AUDIOCODES”
