I'm not sur if am posting in the right forum
I have some DeskPhone 8068 connected to (oxe/8770) OXE10.1
The problem: the phone reboots some times (1 time a week...!) i used telnet to connect to the phone and
taped the command:
defence 99: this is the results (attached image)
I got this "32 Software fatal error"
Question:does that confirmes that there is a bug in this phone software (operating system)? how can i resolve that?
thanks a lot , and sorry for my pooer anglish
sorry if i'm posting in the wrong forum
merci beaucoup!
DeskPhone 8068 reboots
kamallahmer
Re: my ic phone 8082 reboots
The problem seems to be related with Bluetooth handset.
Can you check if the resets only hapens on sets with bluetooth.
Can you check the output of the bthid command taken on the 8082 set.
What is the code of the Bluetooth handset (3GV2705XXXX)
kamallahmer
Re: DeskPhone 8068 reboots
thanks a lot sadim
i will check that by tomorrow
sorry it's about deskphone 8068 (noe mode).
kamallahmer
thanks a lot for your reply
NoePhone > bthid
016
just after doing a telnet to the phone, this line is dispalyed
hard 3MG26102AAAC0XXXXX (guess is the device code not bluetooth handset! am i wrong?)
i am searching how to get the right code
NoePhone > bthid
016
lecoslap
Are you using a bluetooth headset?
I have the same problem but only occurs when connected to the bluetoothh Phantronics Model CS Voyager Legend headset.
