uflash not found (Miniboot)
drmrkam
Post by drmrkam »
Can anyone help ?
I do not understand what is this problem and how I can resolve.
Thanks in advance.
Running fsck ....
/flash: errno = 0xd0001
'/flash/certified/' does not exist, creating...
'/flash/working/' does not exist, creating...
Can't open file (/flash/boot.params)
Attempting to load from the CERTIFIED directory...
Loading kernel from '/flash/certified/Gos.img'...
Cannot find component(alcatelNetworking_kernel.lnk) in package(/flash/certified/Gos.img)!
Cannot find component(kernel.lnk) in package(/flash/certified/Gos.img)!
Unable to load kernel image from file '/flash/certified/Gos.img'.
Unable to boot from the CERTIFIED software release.
[Miniboot]->USB Disaster Recovery Activated
sysUsbDisasterRecoveryTask: ERROR: /uflash not found
[Miniboot]->
Re: uflash not found (Miniboot)
it seams that your flash has a failure (after a lot of years...).
The switch tries to load image from USB (=uflash). But there is no usb stick attached.
You can create your own stick with directory 6400/certified (direct in root). There you copy all image file (G*.img). This stick attach to the switch and power off/on....
The stick you can test before at an other switch: connect it there, command "usb enable" and than "ls /uflash"
Return to “OmniSwitch 6400”
