Ports used on 8082 on OXO
paulosimoes
Post by paulosimoes »
Do some one have the information of all ports that are used on 8082 set in the OXO?
The problem that I have is:
We have 11 OXO R10.2 all of the OXO have set 8082, internally all the 8082 are working fine, and the calls from 8082 in the remotes sites are OK for audio and video, the main problem is in the main site from the 8082 we only can make audio calls to the remote sites, when we try to activate the video we have a ! in the screen.
Paulo Simões
ACSE OXO
sadim
Re: Ports used on 8082 on OXO
Post by sadim »
hi paulo,
I am not a OXO expert, but i think that it uses UDP port 7000
PM
paulosimoes
Thanks Sadim
Hummm can't be a single port, must be a range...have you checked OXO docs available here?
Return to “ON SITE TROUBLES”
