Hey Guys
Need some help here . Im using an external billing system that does not belong to alcatel meaning I'm not using 4760 or 8770.
I need a way for my billing system to be able to connect to my 4400 and alter the users public network category without using the mgr menu.
So what I need is an algorithym to be able to change the extension through alcatels shell commands instead of using mgr to go through the menus.
I need this because we will be limiting the users by credits, for example :
ext 1000 will given 100 credits , when the value of credits gets to 0 , the billing system will automatically block the user from making calls.
Any ideas ?'
Thanks in advanced
Change user public network without going through mgr menu
Re: Change user public network without going through mgr menu
you can use mgr without menu. Search "mgr nodico" on this forum.
i assume you do not wanna use the built in hotel feature... if i'm wrong this is the right one for you. else -> try vads suggestion.
regards...
--- back to basics... focus your eyes on the essential things... ---
regards...
Hi Guys
Vad´s solution I think it will work fine, I will be testing this with our billing system .
Thank you very much .
