hi guys
i have a 8082 which doesn´t want to get updated. i do the same as everytime with the aleds tool. is see in the aleds tool that the config.mac.xml and the aleds-ict-crt file is loaded, and after about 3 min in step 3 it reboots with the error:
Could not retrieve the following files: https://ip_of_server/dmictouch/config.mac.xml & ${ENETCFG_SIP_FILE}
The sipdata.mac.xml is present, so i don´t know whats is his problem. The Phone is running R200 at the moment...
greets Alex
8082 update
Re: 8082 update
Hi again
i tested with wireshark and find some "bad certificate" messages... i will keep searching...
greets Alex
greets Alex
Re: 8082 update
updating a 8082 is a real timekiller...
regards...
--- back to basics... focus your eyes on the essential things... ---
regards...
ubhatnagar
Re: 8082 update
If you are using ALEDS, hope you are using DM url as http://<engine IP>/vhe
Re: 8082 update
I try upgrade 8082. I have problem on step 3- dmconfig: curl ret: 35 & http code: 000 , what is it ? I wrote in the 8082 - DM url as http://<engine IP>/vhe
afaquekhan
Re: 8082 binary update procedure
Hi All
i try to install 8082 my ic phone with blue tooth handset in alcatel oxe rel 11.0.1 -k 1.520-29 ,pairing of hand set device showing but i can not use Bluetooth hand set because no any response is coming when i lift my hand set on the instrument
afaque
afaque
afaquekhan
Re: 8082 update
Dear All
pls let me know what is the procedure of binary upload in my ic phone 8082 i m facing a problem in bluetooth configuration in oxe rel 11.0.1
Afaque
Afaque
