Hello everyone,
i got a few 8118 handsets and the issue is, that the 8118 cant speak to each other.
--> I call from a 8118 to another 8118. The handset rings. I take off.... nothing. I cant hear anything.
I can ring a 4038, no problem. also to a 310.
Any ideas?
Freeman
Problems between two 8118
- cavagnaro
Re: Problems between two 8118
Codecs? Firewall?
i had such an issue in the past. problem was a wrong wlan design.
investigate the issue with the remote pcap interface of the 8118 and wireshark.
attach the pcap files here. maybe we can see more then.
regards...
--- back to basics... focus your eyes on the essential things... ---
regards...
Hello everybody,
we installed a new Aruba-WLAN setting. Now the 8118 are able to speak to each other.
Hint: We needed to edit the channels: From 802.11 b/g/n to 802.11 a/n (8118 get frozen after connecting to the new W-LAN)
Hope that helps for somebody
greetings
Freeman
greetings
Freeman
