Trying to update the firmware and fails
iaf41
Post by iaf41 »
hello
a got OmniStack LS 6224 and i want to update is firmware
but i dont know exactly how
i download the last firmware i can find "OS6200_v1.7.1.12"
Is there a newer ??
i am working with this guide
http://www.manualslib.com/manual/356427 ... -6224.html
i use cutecom program
and in this page
http://www.manualslib.com/manual/356427 ... =49#manual
it says "Enter the command "xmodem:boot"
so i enter
xmodem:boot
and i get
unrecognized command
what am i doing wrong ??
The main goal
To reach the device graphical interface
But first I wanted to update it
iaf41
Re: Trying to update the firmware and fails
Post by iaf41 »
Another problem
I try to add a new user
But the switch does not receive the command
I work according to the guide
in the main post
Vt-100 being used?
iaf41
Post by iaf41 »
what is vt-100 ?
or "Enviado de meu E6633 usando Tapatalk"
I read basic English
iaf41
Post by iaf41 »
some help Still stuck
Have you at least Googled what is vt100? If you can't answer such questions others won't waste their time with your lack of interest
iaf41
Post by iaf41 »
yes i did
But I found no explanation of what It is
https://www.google.co.il/search?client= ... &gws_rd=cr
iaf41
Post by iaf41 »
so what do i need to do ?
i google more about vt100
and from what i read it is a type of terminal emulation
i try to download it but no luck
i use ubuntu and putty or cutecom is this good ?
iaf41
Post by iaf41 »
this is the firmware file "OS6200_v1.7.1.12.zip"
do i need to send it as is or do i need to open it first ?
iaf41
Post by iaf41 »
ok after a lot of time I upgraded successfully the firmware with aprogram named hyper terminal private edition
i neded to extricate a file named "software.img" from the zip file
and it work
so now i go back to the second problem
i try to add a user and get error
and to other commands as well
Return to “OmniStack LS 6200”
