Thank you for help and answer
I reach my mobile from OXO no problem
I reach TELECOM NETWORK from ALCATEL OXO
From ASTERISK I reach any OXO user
From OXO I each any ASTERISK user
What I don't reach is from ASTERISK to my mobile
To open my DB you need the last release of OMC 10.2.18 you can download the last OMC 10.2.18 from my website : OMNIPCX.INFO
Or if for you is better can click on this link
http://www.omnipcx.info/DOWNLOAD/TECNIC ... lcatel.zip
After ; just this two days : I have made an alternative configuration and it works with my sorprise !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I can reach also my mobile from ASTERISK it seems that it runs
But in my opinion is very badly configuration it is a shit configuration I don't like it
What I have made to go out to reach my mobile
I have made a SIP user and the asterisk has been connected to OXO as a SIP user via trunk
In this way the ASTERISK is just a SIP user of OXO and I made the call via 0 principal trunk as a normal user .
It runs but as you can see is not a private trunk network between OXO and astersk
I wandering way the normal private trunk configuration doesn't run ?
Where is the mistake ?
It has to run and I whant to find where is the mistake
Others have made this integration ?
Nobody can send me the right configuration of OXO and Asterisk ?
Thank you a lot
Emilio
CONNECTION OXO ELASTIX
- tot3nkopf
Re: CONNECTION OXO ELASTIX
No. Trunking works. You have just missed something in your config.
Yes many have this config. It is a normal break out configuration.
I will try to have a look in your DB this afternoon.
Thanks a lot
Emilio
Thanks a lot
Emilio
Was there a resolution on this?
I am having similar troubles, but with fax server in place of Elastix.
Update: Changed Private Numbering to Main Trk Grp 0 0 ARS (before it was Main Trk Grp 0 0 0) ... working now.
It was causing OXO to send SIP error 603 "call rejected" to the fax server.
