Did you try to execute command.exe with "Run as Administrator" option ?
Ominivta 8870 Adminnmc Acount locked
Re: Ominivta 8870 Adminnmc Acount locked
Hi Alex, if I told you that I managed to reset the Directory Manager password and with that I was able to change the AdminNmc password, but once I run the Omnivista8770 client I get an error message "SERVER CANNOT ITITIALIZE!", and I restarted the server but it was keeps the same error, any idea what it can be?
Thank you for your comments.
some of the logs shown (C: \ 8770 \ log \ NMCsvc_mgr_2):
28/09/2020 04:36:46 p.m.] 3796 svc_mgr: Warning: InternalAlarm DLL : Can't bind LDAP Server for AlarmServer IOR
[28/09/2020 04:36:46 p.m.] 3796 svc_mgr: RemoveLdapConnection...#2 no m_config
[28/09/2020 04:36:46 p.m.] 3796 svc_mgr: RemoveLdapConnection...#3
[28/09/2020 04:37:01 p.m.] 3724 svc_mgr: Error: connection to LDAP server failed (error 49: Invalid credentials)
[28/09/2020 04:37:01 p.m.] 3724 svc_mgr: closing LDAP connection
[28/09/2020 04:37:01 p.m.] 3724 svc_mgr: Error: cant extract last threshold for LDAP
[28/09/2020 04:37:01 p.m.] 3724 svc_mgr: Error: cant extract last threshold for SQLA
[28/09/2020 04:37:01 p.m.] 3796 svc_mgr: Warning: InternalAlarm DLL : Can't bind LDAP Server for AlarmServer IOR
[28/09/2020 04:37:01 p.m.] 3796 svc_mgr: RemoveLdapConnection...#2 no m_config
[28/09/2020 04:37:01 p.m.] 3796 svc_mgr: RemoveLdapConnection...#3
[28/09/2020 04:37:16 p.m.] 3724 svc_mgr: Error: connection to LDAP server failed (error 49: Invalid credentials)
[28/09/2020 04:37:16 p.m.] 3724 svc_mgr: closing LDAP connection
[28/09/2020 04:37:16 p.m.] 3724 svc_mgr: Error: cant extract last threshold for LDAP
[28/09/2020 04:37:16 p.m.] 3724 svc_mgr: Error: cant extract last threshold for SQLA
[28/09/2020 04:37:16 p.m.] 3796 svc_mgr: Warning: InternalAlarm DLL : Can't bind LDAP Server for AlarmServer IOR
[28/09/2020 04:37:16 p.m.] 3796 svc_mgr: RemoveLdapConnection...#2 no m_config
[28/09/2020 04:37:16 p.m.] 3796 svc_mgr: RemoveLdapConnection...#3
[28/09/2020 04:37:32 p.m.] 3724 svc_mgr: Error: connection to LDAP server failed (error 49: Invalid credentials)
[28/09/2020 04:37:32 p.m.] 3724 svc_mgr: closing LDAP connection
[28/09/2020 04:37:32 p.m.] 3724 svc_mgr: Error: cant extract last threshold for LDAP
[28/09/2020 04:37:32 p.m.] 3724 svc_mgr: Error: cant extract last threshold for SQLA
[28/09/2020 04:37:32 p.m.] 3796 svc_mgr: Warning: InternalAlarm DLL : Can't bind LDAP Server for AlarmServer IOR
[28/09/2020 04:37:32 p.m.] 3796 svc_mgr: RemoveLdapConnection...#2 no m_config
[28/09/2020 04:37:32 p.m.] 3796 svc_mgr: RemoveLdapConnection...#3
[28/09/2020 04:37:47 p.m.] 3724 svc_mgr: Error: connection to LDAP server failed (error 49: Invalid credentials)
[28/09/2020 04:37:47 p.m.] 3724 svc_mgr: closing LDAP connection
[28/09/2020 04:37:47 p.m.] 3724 svc_mgr: Error: cant extract last threshold for LDAP
[28/09/2020 04:37:47 p.m.] 3724 svc_mgr: Error: cant extract last threshold for SQLA
[28/09/2020 04:37:47 p.m.] 3796 svc_mgr: Warning: InternalAlarm DLL : Can't bind LDAP Server for AlarmServer IOR
[28/09/2020 04:37:47 p.m.] 3796 svc_mgr: RemoveLdapConnection...#2 no m_config
[28/09/2020 04:37:47 p.m.] 3796 svc_mgr: RemoveLdapConnection...#3
[28/09/2020 04:38:02 p.m.] 3724 svc_mgr: Error: connection to LDAP server failed (error 49: Invalid credentials)
[28/09/2020 04:38:02 p.m.] 3724 svc_mgr: closing LDAP connection
[28/09/2020 04:38:02 p.m.] 3724 svc_mgr: Error: cant extract last threshold for LDAP
[28/09/2020 04:38:02 p.m.] 3724 svc_mgr: Error: cant extract last threshold for SQLA
[28/09/2020 04:38:02 p.m.] 3796 svc_mgr: Warning: InternalAlarm DLL : Can't bind LDAP Server for AlarmServer IOR
[28/09/2020 04:38:02 p.m.] 3796 svc_mgr: RemoveLdapConnection...#2 no m_config
[28/09/2020 04:38:02 p.m.] 3796 svc_mgr: RemoveLdapConnection...#3
[28/09/2020 04:38:17 p.m.] 3724 svc_mgr: Error: connection to LDAP server failed (error 49: Invalid credentials)
[28/09/2020 04:38:17 p.m.] 3724 svc_mgr: closing LDAP connection
[28/09/2020 04:38:17 p.m.] 3724 svc_mgr: Error: cant extract last threshold for LDAP
[28/09/2020 04:38:17 p.m.] 3724 svc_mgr: Error: cant extract last threshold for SQLA
[28/09/2020 04:38:17 p.m.] 3796 svc_mgr: Warning: InternalAlarm DLL : Can't bind LDAP Server for AlarmServer IOR
[28/09/2020 04:38:17 p.m.] 3796 svc_mgr: RemoveLdapConnection...#2 no m_config
[28/09/2020 04:38:17 p.m.] 3796 svc_mgr: RemoveLdapConnection...#3
I know this is an old post, but I am having this issue and following these steps is not resolving anything. I have set the line in dse.ldif to set the password as {CLEAR}hugo and i restart the services, but when I run ToolsOmniVista.exe and use 'hugo' as the password, I getdoublezero wrote: ↑16 Feb 2016 05:51 1) Change directory: 8770\SunONE\slapd-8770\config
2) Edit: 'dse.ldif'
3) Modify line: nsslapd-rootpw: {SSHA}5lh……
New entry: nsslapd-rootpw: {CLEAR}hugo
(CLEAR means you can fill in the password in a readable format – like 'hugo')
DON'T SAVE THE MODIFICATON YET!
4) Stop service: 'Sun Directory Server 7.0 Control Center'
Stop service: 'Sun Directory Server Enterprise Edition 7.0'
5) SAVE the modification of 'dse.ldif'
6) Start service: 'Sun Directory Server 7.0 Control Center'
Start service: 'Sun Directory Server Enterprise Edition 7.0'
(The 'Sun Directory Server Enterprise Edition 7.0' should start automatically, if not start it)
7) Use the ToolsOmnivista.exe to change the password of the 'Directory Manager'; otherwise the password isn't encrypted in the 'dse.ldif' file.
ServiceManagerInterface::Init(): Accessing service control manager failed: [5] Access is denied.
execute cmd with administrator priv
