INTOF - HDB3 Error
Tenna
INTOF - HDB3 Error
Post by Tenna »
Hi guys
We are getting a lot of HDB3 errors between on INTOF link on 2 shelfs. The shelf has gone down and then came up. Please if somebody can help here.
I am going to do the fiber tests. But normally would HDB3 be related to the coupler or INTOF Boards.
Tenna
Re: INTOF - HDB3 Error
see related incident , try to reset both intofos
sadim
Post by sadim »
Did you check the synchronization of the public network access's ?
You have many INTOF shelves and only two with error?
Tenna
Post by Tenna »
Hello everyone
Please accept my sincere apologies for this. The Error was HDLC Frame Retransmission. Only one set of INTOFs A & B is generating this. All the other Shelfs connected over INTOF is ok.
I did a hard reset on the INTOFS, then for few days it did not generate these errors and then it started again.
Whilst I would be doing the fiber test, can it be that the INTOF board is bad.
Tenna
Try replace one INTOF set with another - you will have error on the same FO cores or on the same INTOF set.
Return to “Shelf”
