Alcatel 7210 SAS-M and SAS R, untagged and tagged on same port
ouro_m
Post by ouro_m »
Need some help as I am relatively new to Alcatel.
So basically I have a tagged (vlan 100) EPIPE to a port (eg 1/1/2), and I also wanted to configured an VPLS that is untagged to that same port (1/1/2) as well.
Is it possible to have all untagged traffic goes to the VPLS while VLAN 100 trafffic to my EPIPE?
dayres
Re: Alcatel 7210 SAS-M and SAS R, untagged and tagged on same port
Post by dayres »
Did you get to the bottom of this? I just tested the configuration on a SAS-M to confirm and yes, you can. I'm not sure about the SAS-R
--Dave
ouro_m
Post by ouro_m »
Can you please let me know what configuration example you have to show me as I am tryign to work it out
zeips
Post by zeips »
Probably right now you have epipe with SAP 1/1/2:100. You can try to add to your vpls SAP 1/1/2:* - this should grab everything (unttaged and tagged packets) except packets with vlan 100 which should match your epipe with sap 1/1/2:100.
Port encap: do1q
thecandymancan
Post by thecandymancan »
sap 1/1/2:0 will capture untagged frames only, if thats your requirement. All covered in my super awesome book listed in my sig :)
ouro_m
Post by ouro_m »
I got it working using 1/1/2:* , tried using sap 1/1/2:0 but says port / encap type is wrong
Here is the configs i got it working with
port 1/1/2
description "TEST*
ethernet
mode hybrid
access
exit
encap-type dot1q
exit
no shutdown
vpls 10002 customer 1 create
description "TEST"
service-mtu 9194
stp
shutdown
exit
sap 1/1/2:* create
exit
spoke-sdp 10122:10001870 create
no shutdown
exit
no shutdown
epipe 10001 customer 1 svc-sap-type any create
description "TEST"
service-mtu 9194
sap 1/1/2:100 create
exit
spoke-sdp 10139:10003871 create
no shutdown
exit
no shutdown
thecandymancan
Post your error output, works fine for me
*A:7210# configure service epipe 100001 svc-sap-type any customer 1 create
*A:7210>config>service>epipe$ sap 1/1/4:0 create
*A:7210>config>service>epipe>sap$ back
*A:7210>config>service>epipe$ info
shutdown
sap 1/1/4:0 create
exit
ouro_m
Post by ouro_m »
can you show me the who command include VPLS as untagged, epipe as tagged and the port config please to get tha tworking?
thecandymancan
off the top of my head:
conf port <port>
shut
ethernet enca dot
no shut
/conf ser vpls <sid> cust 1 cre
sap <port>:0 cre
back
mesh-sdp <sdp> cre
back
no shut
/conf ser ep <sid> customer 1 cre
sap <port>:<tag> create
back
spoke-sdp <sdp>:<vcid> crea
back
no shut
exit all
Return to “7210 SAS”
