There any of you worked in the last period with AVISO ? In release 3.0 it's written that we can use IPDSoftPhone. I made to work with release 11.x but after a session we don't see the result in Report module. If i'm using IPTouch phones then everything look ok.
The strange is that after a manual call i have all the information after like: MOS, Jitter, Roudtrip delay etc.
It's anybody succeeded to make it work with IPDS?
Adrian
AVISO - Voip Assesment Tool and UAIP SoftPhone
- stancu_adi
- stancu_adi
Re: AVISO - Voip Assesment Tool and UAIP SoftPhone
Seems nobody. Meanwhile I opened an eSR to ALE and received a newer version of AVISO which is working perfectly with the IPDSoftPhone.
BR,
Adrian
BR,
Adrian
do you know where I can find any documentation of AVISO?
I keep looking to the internet and BPWS but still I cant find any.
Thanks!
Thanks!
- cavagnaro
Please don't post the same question on several threads. Wait for an answer.
