MADA 1 replace by MADA 3 possible ?
Ola Josh
Post by Ola Josh »
Hey ,
I had a question.
To replace a MADA1 by a MADA3 is that possible?
What should you consider?
And if you have a GA or GD card replaced by a GA2 or GD 2 this also has implications for the system?
Regards, Josh.
tgn
Re: MADA 1 replace by MADA 3 possible ?
Post by tgn »
Ola Josh wrote:Hey ,
I had a question.
yes, it is. but you have to manage this in the database. also you can use only as much compressor declared in your oxe license...
Ola Josh wrote:And if you have a GA or GD card replaced by a GA2 or GD 2 this also has implications for the system?
GA/GD and GA2/GD2 are using the "same" binaries. so no configuration change must be done in database. but the binary is provided by oxe and i didn't know since which oxe version the GA2/GD2 are supported.
regards...
Ola Josh
Post by Ola Josh »
Thanks for you're answer .
BR , Josh..
jasb
Post by jasb »
MAC address of this cards in database anyway :)
Return to “Media Gateway”
