Database type
lazlow
Database type
Post by lazlow »
Hello everybody,
I don't know if this is the right place to ask this question, but does anyone know what type of database the Alcatel OmniPCX Enterprice 4400 uses?
alex
Post by alex »
From Release 2 they use c-tree plus DB from Faircom
http://www.faircom.com/
lazlow
Post by lazlow »
Thanks, Alex!
Are you familiar with the db?
alex
Post by alex »
More or less everyone here is familiar :wink: with "cuser" command.
If you mean proper knowledge of its structure - no.One may only guess what is relations between different tables.
lapepe
Post by lapepe »
Hello....
What is version db in Alcatel OXE R6.0???
Is it last version c-tree plus V8.14???
LaPEPE
pka
Post by pka »
Hi Guys,
is it possible to access the database anyway? We found some limitations of CCS reports and we would like to have reports accessible online on intranet.
Thaks a lot
resen
hi
Post by resen »
have anyone try to import CCS statistics files (*.sta) to another source like SQL.
now i do it like this. CCS >> exel >> vbs script >> sql
but this model is now comfortable
have anyone some ideas ?
Wow.. Does it gives you anything good ?
sadim
Post by sadim »
Some time ago i have develop a application that retrieves all the ccd information, the counters used by ccs and all the ohers (ie: calling number, initial number called, answering agent, begin date, end date, ) and then put all this info in a Access DB , but i still not sure what price (if any) should i charge for it.
Send it to me, let me try it, and I'll tell you if it worth gold or no :-)
Return to “GENERAL”
