8068 Phone Displays BAD TFTP
Gerry
Post by Gerry »
I have programmed a set with Static Configuration.
IP Address is static on local network
Gateway and Subnet mask is correct
TFTP is statically set and correct.
Release: l1.301.26a (11.1)
Have 4028 on same location that is working fine .
The 8068 displays BAD TFTP.
Any Ideas??
Gerry
:shock:
enio.eltz
Re: 8068 Phone Displays BAD TFTP
Post by enio.eltz »
Do you have any trace to check?
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
Check the lanpbx configuration.
Any security features activated on the switch port?
nperalta
Post by nperalta »
check vlan, and routing to oxe, tracert to oxe from a pc.
Return to “Users”
