New system and i am setting up database. CS2 was working fine (system software + database) just yesterday but i decided to switch off power after work. This morning it is misbehaving; cannot boot to allow mgr. Doing all this with CS2 in slot 0 and i tried on both 9 slot and 3 slot -just the same.
See the attached; top part is booting script and the last part is when i switch off the CS2 manual switch.
CS2 Misbehaviour
philasphe
CS2 Misbehaviour
Re: CS2 Misbehaviour
which hardware version has the cs-2 board?
regards...
regards...
philasphe
I don't understand what you mean by hardware version but if you mean software, it is R10.1
there must be a sticker with an alcatel part number near the harddisk.
regards...
regards...
philasphe
Ok, see the attached
philasphe
I sorted the problem by formatting HDD, but not sure if it will appear again and here is how;
Moved the HDD to crystal CPU7-2, ran the grubboot ETHER
Took it back to CS2 and load OS
So far so good, i even switched off power several times and all is well.
