Dect coverage intermittent
Everything about the PWT, IBS, RBS, DECT..
fernando2002
Re: Dect coverage intermittent
Post by fernando2002 »
Vincent wrote:- there are 22 pieces of DECT8 boards on Node 3
- incvisu shows a few '1376' errors and lots of '3753 -1' but I should monitor it again
once I will switch back-off the 4 carriers.
- [infocs] answers "No synchronizing board is declared in the system, or synchronizing
board priority is 255"
I have no knowledge at all about synchronization, the only thing I know is that there are
two INTOF-B boards (Main and Standby) in the same shelf, and similar boards as well in other nodes, and I guess they have something to do with synchro. There no alarms related to them and they their red Led isn't flashing.
Thanks !
how do we correct or fix this?
I believed I am having the same issue with my dect boards.
(1)xa000001> infocs
| N_CR | N_CPL | TYPE | N_ACCES | PRIO | SYNC_CLOCK | TG/LK |
* NO SYNCHRONIZING BOARD IS DECLARED IN THE SYSTEM *
* OR SYNCHRONIZING BOARD PRIORITY IS 255 *
+========= Synchro DECT ====================+
| N_CR | N_CPL | TYPE | DECT_CLOCK |
+========= Synchro phase thru INTOFS ====================+
PHASE_NO_OPERATION values=0,0
cr= 5 cpl= 00 BS1/2/3/4 RPN : 140/141/142/143 State : OUTSERV/OUTSERV/OUTSERV/OUTSERV
cr= 5 cpl= 02 BS1/2/3/4 RPN : 144/145/146/147 State : OUTSERV/OUTSERV/OUTSERV/OUTSERV
cr= 5 cpl= 04 BS1/2/3/4 RPN : 148/149/150/151 State : OUTSERV/OUTSERV/OUTSERV/OUTSERV
cr= 5 cpl= 08 BS1/2/3/4 RPN : 152/153/154/155 State : OUTSERV/OUTSERV/OUTSERV/OUTSERV
cr= 5 cpl= 09 BS1/2/3/4 RPN : 156/157/158/159 State : OUTSERV/OUTSERV/OUTSERV/OUTSERV
cr= 5 cpl= 11 BS1/2/3/4 RPN : 160/161/162/163 State : OUTSERV/OUTSERV/OUTSERV/OUTSERV
cr= 5 cpl= 14 BS1/2/3/4 RPN : 164/165/166/167 State : OUTSERV/OUTSERV/OUTSERV/OUTSERV
cr= 5 cpl= 15 BS1/2/3/4 RPN : 168/169/170/171 State : OUTSERV/OUTSERV/OUTSERV/OUTSERV
cr= 5 cpl= 16 BS1/2/3/4 RPN : 172/173/174/175 State : OUTSERV/OUTSERV/OUTSERV/OUTSERV
cr= 5 cpl= 17 BS1/2/3/4 RPN : 176/177/178/179 State : OUTSERV/OUTSERV/OUTSERV/OUTSERV
cr= 5 cpl= 18 BS1/2/3/4 RPN : 180/181/182/183 State : OUTSERV/OUTSERV/OUTSERV/OUTSERV
cr= 5 cpl= 19 BS1/2/3/4 RPN : 184/185/186/187 State : OUTSERV/OUTSERV/OUTSERV/OUTSERV
cr= 5 cpl= 22 BS1/2/3/4 RPN : 188/189/190/191 State : OUTSERV/OUTSERV/OUTSERV/OUTSERV
cr= 5 cpl= 23 BS1/2/3/4 RPN : 192/193/194/195 State : OUTSERV/OUTSERV/OUTSERV/OUTSERV
cr= 5 cpl= 24 BS1/2/3/4 RPN : 196/197/198/199 State : OUTSERV/OUTSERV/OUTSERV/OUTSERV
cr= 5 cpl= 25 BS1/2/3/4 RPN : 200/201/202/203 State : OUTSERV/OUTSERV/OUTSERV/OUTSERV
cr= 5 cpl= 26 BS1/2/3/4 RPN : 204/205/206/207 State : OUTSERV/OUTSERV/OUTSERV/OUTSERV
cr= 5 cpl= 27 BS1/2/3/4 RPN : 208/209/210/211 State : OUTSERV/OUTSERV/OUTSERV/OUTSERV
(1)xa000001>
All boards in one shelf?
Declare at least one of the boards as DTM (this post contained this already)
It would also help if you read the system documentation. DECT system is well documented.
fernando2002
tot3nkopf wrote:All boards in one shelf?
yes all boards in one shelf.
Restarting node 1 helps and put all antennas in service.
Return to “Wireless configuration and sets”
