OXE break E1 ISDN
mokhtar ACFE
OXE break E1 ISDN
Post by mokhtar ACFE »
hello,
Thank you in advance to those who could help me
I had to remove a board E1 ISDN ,but i have already this error
Delete \OmniBRN\Shelf::5\Board::3
Board Address : Term. are connected to the board
i delete all term connected to this board by deletin all trunk and trunk group .
Can any one help me .
tgn
Re: OXE break E1 ISDN
Post by tgn »
what output do you have with command...
trkstat 5 3
regards...
mokhtar ACFE
thnk you , I have this output .
| T R U N K S T A T E - PRA T Coupler Crystal_nbr = 5 |
| OUT OF SERVICE Coupler Nbr = 3 |
| Access 0 Type : T2 access : ENABLED level2 : DCONNECT2 |
| Trunk Grp |
| Channel 1 2 3 4 5 6 7 8 9 10 11 12 |
| State -- -- -- -- -- -- -- -- -- -- -- -- |
| Trunk Grp |
| Channel 13 14 15 17 18 19 20 21 22 23 24 25 |
| Trunk Grp |
| Channel 26 27 28 29 30 31 |
| State -- -- -- -- -- -- |
| ALARM COUNTERS |
| NOS | AIS | LOS | FEC/CEC | RAI |
| 0 | 0 | 0 | 0 | 0 |
| NOS : no signal | LOS : loss of synchronization |
| AIS : alarm indication signal | FEC/CEC : Frame/Checksum error counter |
| RAI : remote alarm indication | |
mokhtar ACFE
the problem is solved, I changed the board by a new card E1 ISDN . Now i can delete all trunk group .
thanks
tgn
Post by tgn »
thx2 4 sharing
regards...
Usually this happen - when we delete access but users use this TG. We cannot see access, but when we try to delete board or use access in another TG - PBX not allow this.
After PBX restart - access can be used/ board deleted. I use another solution - after some times - I delete access again (only via mgr) - delete the same access from the TG.
My opinion - when we delete access first time - access deleted from HDD database but not deleted from RAM database (access used). We cannot delete access from 4760 (access not present on HDD) but mgr allow to say - delete access X-XX-X from TG XXX
jainmanish94
Post by jainmanish94 »
Hello Team,
can anyone help me to tell what is the uses of ISDN Access - E1 PRA-T2 in OmniPCX Device.
there are two ports one is for PBX and another is for NETW and one my copper cable is connecting on NETW port which is going to PTN devices.
here i just want to know what is the exctual uses of this E1 Port.
Return to “Shelf”
