We are using Omni 400 Pabx and how would I know who's giving Ip address on my IP phone.
CIsco Switch uses default Vlan
Cisco Router no Configuration for Ip phone.
On our DHCP server there no config for IP phone which is the segment is 10.34.62.X
Now from PaBX I verified using netadmin -m then dhcp config but the result is no "DHCP Configuration"
i run the command Ippstat and it displayed all 10.34.62.0 sgment.
tried to check my IPphone IP touch 4038 physically under the settings theres no display for static or dynamically assign only the ip addres.
thanks
How to verify DCHP Configuration?
Re: How to verify DCHP Configuration?
output of command dhcplease on oxe?
regards...
regards...
searching1
I have input the command dhcplease but there is no display?
Do you think it manually configured on IP phone.
I'm new handling pabx system.
thanks
thanks
- Krusty65
To check the settings on the phone power it off and when it reboots and gets to 2 of 5 press the i key followed by #
You can then navigate to the IP settings to see if the phone is set for DHCP (dynamic) or static, might give you some more info
K.
K.
