Status remote shelf
telco1
Status remote shelf
Post by telco1 »
I know the telnet command to see the status of the boards of a shelf (eg "config 2 -v -d") but I'd like to know the command to see if a remote shelf is still active and the link between the pbx and remote shelf is up. Can you get a list of all links to remote shelves and see the status of the links?
Anyone here who can help me with this please?
Thanks a lot!
Re: Status remote shelf
shelf? Shelf doesn't work alone...needs a board. So doing config 2 will show all boards on it.
If all are REG NOT INIT then shelf is out
You will also have an alarm about it
telco1
Post by telco1 »
Thank you
And suppose it is a media gateway or voice hub, how do i see the status of the link and if all is ok?
tgn
Post by tgn »
the board in controller slot must be in service.
mg controller slot == 0
vh controller slot == 1
regards....
telco1
Post by telco1 »
Thanks!
Return to “Shelf”
