Entity Unknown
la_toupie
Entity Unknown
Post by la_toupie »
Hi all,
I've a lot of alarms about entity :
Incident 1302, entity 21155 unknown
This incient exist since R5.1 for me...
Have you got an idea about it ?
simon_DUP
Post by simon_DUP »
hi!
I had the same trouble on a 5.x
Alcatel told me to filter the incident........
Sim.
la_toupie
Post by la_toupie »
Always the same answer from Alcatel :?
Do you know if one patch delete this incident ?
wizzy
Post by wizzy »
Same problem on release 6.0.1
Yo..
I worked on a linux release today, and saw this entity 21155 unknown too..
bbbaaahhh..
la_toupie
Post by la_toupie »
The worst is that I've not only this entity but others. At each time, an impossible number for entity... :x
wizzy
Post by wizzy »
Still no luck :evil:
09/06/05 09:14:57 000001M|00/14/0/000|=3:1302=Unknown entity nb 10751
09/06/05 09:15:27 000001M|00/14/0/000|=3:1302=Unknown entity nb 10751
Who can bit this one:
06/06/05 08:42:17 000001M|00/21/0/000|=3:1302=Unknown entity nb -21151
a minus one !
la_toupie
Post by la_toupie »
Always nobody ?
Hum.... :?
la_toupie
Post by la_toupie »
I filled the fields "Night" and "Day" of all the CDT of the entities and the operators groups and since more incidents :wink:
Return to “ON SITE TROUBLES”
