Lync integration with OXO
Jtmurphy76
Post by Jtmurphy76 »
Has anybody successfully implemented Lync intergration with an OXO?
Would a mediation gateway be required between the 2 ?
Search forum please
jas13
Re: Lync integration with OXO
Post by jas13 »
yes ,
its just simple as you create a sip trunk between the two, need a gateway to redirect the external calls, trunk lines will be terminated on the gateway.
My gateway was SONOS SBC
jplaku
Post by jplaku »
Hi jas13,
I am trying to configure Direct Sip Trunk between OXO and Lync 2013 Mediation Server.
Microsoft says Alcatel Lucent is not qualified neither supported as Gateway/PBX for Lync 2013 Server.
Is Gateway mandatory between the two?
If yes, what is recommended as gateway?
Would a cisco 2800 series with voice services do the job?
Could you please be more specific on configuration steps on OXO to achieve this?
