Extensions forwarded in node disconnects when called from other node
thanzeel
We have an issue in one customer. When an extension in Node 2 is forwarded to external number and Node 1 extension calls this extension, the call gets dropped. We have seen this issue when the PRI is more than 75% full in Node 2. On no traffic on PRI in Node 2 we dont see the issue. But when dialled locally in Node 2 there is no issue in any case.
If we try from Node 2 the same scenario in Node 1, we face no issues in this case.
Needing your urgent help in this query.
Re: Extensions forwarded in node disconnects when called from other node
t3 traces , , internode links abcf2-T2 OR ip ? external trunks are them connected to node 2 or node1? , have you managed dpnss prefix
may be some of B channel Are reserved ..
thanzeel
Internode links in abcf ip.... External trunks are independent in node2 and node1.. dpnss prefix is managed..
for forwarding the vpn overflow must have two free channels to build up the connection. check vpn ts under trunk group. must be 100 if trunk group only used for vpn overflow.
regards...
┌─Help: VPN TS %──────────────────────────────────────────────────────────────┐
│ CANCEL to close this window │
│ Enter an integer value │
│ within the following range: │
│ 0 to 100 │
│ VPN TS % │
│ This attribute gives the IT channel charge allocated to the VPN overflow so │
│ as to avoid too much occupation of channels able to manage normal traffic. │
thanzeel
This is in the node which is forwarding the extension? I'll check and keep you updated.
thanzeel
I have checked the value on the trunk groups... it is 50... What should be the recommended value for this? Do I need to restart the trunks after this change?
thanzeel
i
thanzeel
I checked the value in IP Trunk it is 100.. but for the PRI Trunks it is 50...tgn wrote:for forwarding the vpn overflow must have two free channels to build up the connection. check vpn ts under trunk group. must be 100 if trunk group only used for vpn overflow.regards...Code: Select all
┌─Help: VPN TS %──────────────────────────────────────────────────────────────┐ │ │ │ CANCEL to close this window │ │ │ │ Enter an integer value │ │ within the following range: │ │ 0 to 100 │ │ │ │ VPN TS % │ │ This attribute gives the IT channel charge allocated to the VPN overflow so │ │ as to avoid too much occupation of channels able to manage normal traffic. │ │ │ └─────────────────────────────────────────────────────────────────────────────
thanzeel
Please find attached working and non working traces
"These aren't the traces (droids) you're looking for."
--- obivan oxenobi
--- obivan oxenobi
