Another basic crontab question.
Tha Tawa'S
Post by Tha Tawa'S »
Hi all,
i wrote a script named .cmatin
It works fine.
With mtcl's account, I also put it into crontab with crontab -e and it worked fine too unil the next CPU reboot like this :
55 06 * * * /DHS3bin/mtcl/.cmatin
Indeed, after each CPU reboot, the line into crontab disappears. i don't understand why. need help !
And if I edit crontab with root account, it does not work properly, I mean, rsult's command are not forwarded to temp files.
thank you.
Tha Tawa'S
Re: Another basic crontab question.
I just add that I would prefer script works with mtcl's account instead of root account.
Best configuration regarding owner and perissions..
OXE version is R10.1.1-j2.603.35
alex
Post by alex »
Use "cfgCron" command for editing crontab.
Write a script to filter incidents.
Tha Tawa'S
Thank you Alex.
you have redirected me to one of my old post.... :)
Also, after test made on virtual machine, it seems that modify mtcl.cron then crontab -e works after reboot.
I will try cfgCron also.
:lol: :lol: :lol:
alex
Post by alex »
Tha Tawa'S
Every time you start the OXE, there are a ton of scripts that start too.
One of them make sure that there is no weird users created in /etc/passwd for example, and another one check the crontab for anything that was not setup manually, which is your case.
Tha Tawa'S
Thanks for this precision
Return to “Linux tricks”
