not able to creat Attendant Set
deepakparmar
Post by deepakparmar »
Gives Error: Associated CDT already exist
Is anybody knows, why this error is coming
Re: not able to creat Attendant Set
You have another one already created with the same number. Check your Numbering plan for that.
Regards.
deepakparmar
Already chkd in numbering plane and also chkd in Attendant set...
but no where I could find ...the number.
I am creating Attendant ser with directory number A000.
Deepak
run a checkdb
When you create att set you must manage attendant Id. For this Id will be created CDT.
Check - for creation you use unique Id and in "attendant set CDT" absent CDT for this attendant set Id.
Return to “Attendant”
