Retrieve the MyIC Phone SDK
pierok
my PC just crashed and I thought i could download again the SDK for the myic phone. but I just saw that the link is broken from the developper site.
could anyone send me a version of the myic sdk so as i can continue developping my apps for the 8082 ?
that would be great.
thanks guys
thanks guys
Madorianer
Re: Retrieve the MyIC Phone SDK
hi there, got the same problem no more link to SDK download. Any possibility to get hands on?
Thanks!
Thanks!
ctrockel
hi there, got the same problem to download the SDK . Any possibility to get hands on?
I would like to use it as a sip extension but not able to configure the sip section directly on the phone.
Thanks!
Thanks!
rachlilas
My IC Phone SDK is no longer available for free: it is now part of the AAPP program!
This is mainly because the SDK is no longer updated and supported by ALE.
If you intend to develop a webapp on the 8082 you have to become AAPP member and justify your needs then ALE will decide to help you or not.
At least you should get the SDK as it is with no help and no support.
Rgds
Rgds
- frank
Rachlilas,
The SDK is still available for free.
You can actually contact the AAPP and get the SDK without being a member.
I think actually you just need to register. It does not cost a dime, and you'll have access to it.
IF you want R&D help, then you need to become an AAPP member.
ctrockel
They denied our request cause the development should generate revenue for them.
Could someone help
Could someone help
