ETH-MGMT
dadis1988
ETH-MGMT
Post by dadis1988 »
Hallo Guys.
I`m new to the Alcatel community.
I`m trying to upload and download the config file from the 7210 SR using the ETH-MGMT port.
I have a TFTP on my laptop with IP 192.168.0.2/24
And the 7210 is set to 192.168.0.1/24
When i try to ping them it doesn`t work. I can Ping from my Laptop to 7210 but when Pinging from 7210 to Laptop i recive an error no route to the destination IP.
Does anyone know how to solve this?
Dawid Kowalczys
paramount
Re: ETH-MGMT
Post by paramount »
You will probably need to ping from the out of band routing instance:
Try:
ping router management x.x.x.x
Cheers
zeips
Re: ETH-MGMT
Post by zeips »
ETH-MGMT is the management interface "out of band", so your ping does't work because this network is not in the routing table.(u can verify by show bof/show router route-table)
But if u can ping it from your PC try to enter "file" command on the device and try to copy config.cfg to your tftp(or download it)
rekeds
Re: ETH-MGMT
Post by rekeds »
yep, router "management" is needed to ping from "out of band".
Return to “7210 SAS”
